url: /docs/guides/plugins/apps/administration/add-cms-element-via-admin-sdk.md
# Add CMS Element
## Overview
This guide explains how to create a new CMS element using the Meteor Admin SDK. The example plugin is named
`SwagBasicAppCmsElementExample`, following the naming conventions used in other guides.
## Prerequisites
* Familiarity with creating [Plugins](../../plugins/plugin-base-guide.md) or [Apps](../app-base-guide.md)
* Familiarity with [creating custom admin components](../../plugins/administration/module-component-management/add-custom-component.md#creating-a-custom-component)
* Understanding of the [Meteor Admin SDK](meteor-admin-sdk.md)
::: info
This example uses TypeScript, which is recommended but not required to develop Shopware.
## Creating your custom element
Similar to [creating a new custom element via plugin](../../plugins/content/cms/add-cms-element.md), this guide describes how to create a new custom element via an app.
Creating a new element requires the Meteor Admin SDK.
::: info
Apps can also add CMS blocks declaratively via `cms.xml` without the Meteor Admin SDK.
That approach is simpler but limited to reusing existing Shopware elements inside the block's slots.
See [Add custom CMS blocks](../content/cms/add-custom-cms-blocks) for details.
The example demonstrates a scenario where a shop manager can configure a video ID to display a Dailymotion video.
### Target structure
Any file structure works for apps, as everything is loaded via iFrame. Shopware recommends using Vue 3 single-file components (SFCs).
When the app is complete, the file structure will look like this:
```bash
// SwagBasicAppCmsElementExample/src/Resources/app/administration/src
├── base
│   └── mainCommands.ts
├── main.ts
├── viewRenderer.ts
└── views
    └── swag-dailymotion
        ├── swag-dailymotion-config.vue
        ├── swag-dailymotion-element.vue
        └── swag-dailymotion-preview.vue
## Initial loading of components
The entry point is the `main.ts` file:
```javascript
import { location } from '@shopware-ag/meteor-admin-sdk';
if (location.is(location.MAIN_HIDDEN)) {
    // Execute the base commands
    import('./base/mainCommands');
} else {
    // Render different views
    import('./viewRenderer');
Use `if(location.is(location.MAIN_HIDDEN))` to **load the main commands** defined in `mainCommands.ts`.
This branch loads logic only — no templates are rendered into the Administration here.
The `else` case loads the view templates via `viewRenderer.ts`.
### Loading all required templates
Next, create the `viewRenderer.ts` file, which loads the three required Vue SFCs for a CMS element:
* `swag-dailymotion-config.vue`, which will handle the content of the CMS element configuration
* `swag-dailymotion-element.vue`, which represents the actual target element in the CMS
* `swag-dailymotion-preview.vue`, which is responsible for the preview when selecting the CMS element in its selection
  screen
Each file is named after its component and prefixed with `swag-dailymotion` (vendor prefix) to avoid naming conflicts.
The following example shows how component loading via `viewRenderer.ts` is implemented:
```javascript
import { createApp, defineAsyncComponent, h } from 'vue';
// watch for height changes
location.startAutoResizer();
const locations = {
    'swag-dailymotion-element': defineAsyncComponent(
        () => import('./views/swag-dailymotion/swag-dailymotion-element.vue'),
    'swag-dailymotion-config': defineAsyncComponent(
        () => import('./views/swag-dailymotion/swag-dailymotion-config.vue'),
    'swag-dailymotion-preview': defineAsyncComponent(
        () => import('./views/swag-dailymotion/swag-dailymotion-preview.vue'),
const app = createApp({
    render: () => h(locations[location.get()]),
app.mount('#app');
The `locations` map connects each Shopware-provided location ID to the corresponding Vue component. `location.get()`
returns the current location ID so the correct component is rendered inside the iFrame.
Location IDs are a core concept of the Meteor Admin SDK — Shopware provides dedicated `locationIds` as injection points
for your templates. For CMS elements, these IDs are **auto-generated** from the element name plus the suffixes
`-element`, `-config`, and `-preview`. They become available once the element is registered (see the next section).
> **Learn more**: See the [Meteor Admin SDK locations reference](/resources/admin-extension-sdk/concepts/locations) for a full overview of the concept.
## Registering the block and element
The Shopware CMS distinguishes between two concepts:
* A **block** is the selectable container that appears in the block picker (organised by categories such as *Text*, *Image*, *Video*, etc.).
  Users add blocks to a section, and each block contains one or more slots.
* An **element** is the content type that lives inside a slot (e.g., a video player, an image, a text).
  Elements can also be swapped inside an existing slot via the element-replacement modal.
The registration method you call determines where your addition is reachable:
| What you call             | Where it appears        |
| `registerCmsElement` only | Element-replacement modal only (the  icon on an existing slot) |
| `registerCmsBlock` only   | Block picker under the chosen category — but the slot renders nothing until an element is also registered                                   |
| Both                      | Block picker **and** element-replacement modal        |
To make your CMS addition fully discoverable and functional, call both.
Go to `mainCommands.ts` and add both registrations:
```javascript
import { cms } from '@shopware-ag/meteor-admin-sdk';
const CMS_ELEMENT_NAME = 'swag-dailymotion';
export const CONSTANTS = {
    CMS_ELEMENT_NAME,
    PUBLISHING_KEY: `${CMS_ELEMENT_NAME}__config-element`,
// Makes the block appear in the block picker under the "Video" category
void cms.registerCmsBlock({
    label: 'Dailymotion video',
    category: 'video',
    slots: [{ element: CONSTANTS.CMS_ELEMENT_NAME }],
// Registers the element that fills the block's slot
void cms.registerCmsElement({
    defaultConfig: {
        dailyUrl: {
            source: 'static',
            value: '',
The `category` field of `registerCmsBlock` controls which group the block appears in:
`'video'`, `'text'`, `'image'`, `'text-image'`, `'commerce'`, `'sidebar'`, `'form'`, or a custom string (which creates a new category group).
The `slots` array lists the element types each slot of the block accepts.
As a best practice, use a **constant** for the CMS element name and the publishing key.
The publishing key must be the element name followed by the `__config-element` suffix.
## Templates and communication with the Administration
The remaining files are the Vue single-file components inside the `views` folder. Create a folder with the full
component name containing three files as shown below:
```bash
views
### Element ID
When Shopware renders any of the three CMS iFrames, it automatically appends the ID of the current CMS element instance as an `elementId` query parameter to the iFrame URL:
```http request
https://your-app-server/...?elementId=<uuid>
Use this ID together with the publishing key to address the correct element's data in Shopware:
```javascript
const params = new URLSearchParams(window.location.search);
const elementId = params.get('elementId');
const dataId = `${CONSTANTS.PUBLISHING_KEY}__${elementId}`;
### The config file
The following section describes each file, starting with `swag-dailymotion-config.vue`:
```html
<template>
  <div>
    <h2>Config!</h2>
    Video-Code: <input v-model="dailyUrl" type="text"><br>
  </div>
</template>
<script setup lang="ts">
import { onBeforeMount, ref, computed } from 'vue';
import { data } from '@shopware-ag/meteor-admin-sdk';
import { CONSTANTS } from '../../base/mainCommands';
const dailyUrlValue = ref('');
const dailyUrlSource = ref('static');
const selectors = ['config.dailyUrl.value', 'config.dailyUrl.source'];
const dataId = computed(() => {
    return elementId
        ? `${CONSTANTS.PUBLISHING_KEY}__${elementId}`
        : CONSTANTS.PUBLISHING_KEY;
const dailyUrl = computed({
    get(): string {
        return dailyUrlValue.value || '';
    set(value: string): void {
        dailyUrlValue.value = value;
        data.update({
            data: {
                config: {
                    dailyUrl: {
                        value: dailyUrlValue.value,
                        source: dailyUrlSource.value,
onBeforeMount(async () => {
    const value = await data.get({
        selectors,
    }) as { 'config.dailyUrl.value': string; 'config.dailyUrl.source': string };
    if (value) {
        dailyUrlValue.value = value['config.dailyUrl.value'];
        dailyUrlSource.value = value['config.dailyUrl.source'];
</script>
**Key points:**
* `data` is imported from the Meteor Admin SDK and handles all data exchange between the app and Shopware
* `dataId` is derived from the `elementId` query parameter appended by Shopware to the iFrame URL, combined with `CONSTANTS.PUBLISHING_KEY`
* `data.get()` accepts an optional `selectors` array so only the relevant fields are fetched; the result is a flat object keyed by selector path (e.g. `value['config.dailyUrl.value']`)
* `data.update()` sends only the changed config structure back to Shopware — not the entire element
* The current config is fetched via `data.get()` in `onBeforeMount` and linked to the computed property `dailyUrl`; the setter calls `data.update({ id, data })` to persist changes
![The image shows the configuration modal for a dailymotion video CMS element. The modal contains one text input for the Dailymotion video ID, a caption for the input and a title.](../../../../assets/add-cms-element-via-admin-sdk-config.png "Dailymotion config modal")
### The element file
`swag-dailymotion-element.vue` contains the main rendering logic for the CMS element in the Administration:
```html
<template>
  <div class="sw-cms-el-dailymotion">
    <div class="sw-cms-el-dailymotion-iframe-wrapper">
      <iframe
        frameborder="0"
        type="text/html"
        width="100%"
        height="100%"
        :src="dailyUrl"
    </div>
  </div>
</template>
import { ref, computed, onBeforeMount } from 'vue';
const dailyUrl = computed(() => {
    const code = dailyUrlValue.value || 'x8hc5d6';
    return `https://www.dailymotion.com/embed/video/${code}`;
    return elementId
        selectors,
    if (value) {
    data.subscribe(
        dataId.value,
        (response) => {
            const responseData = response.data as {
                'config.dailyUrl.source': string;
            dailyUrlValue.value = responseData['config.dailyUrl.value'];
            dailyUrlSource.value = responseData['config.dailyUrl.source'];
        { selectors },
</script>
<style scoped>
.sw-cms-el-dailymotion-iframe-wrapper {
    height: 500px;
</style>
**Key points:**
* `data.get()` fetches the initial element config using the element-specific `dataId`
* `data.subscribe()` keeps the element in sync whenever the config changes — it receives the same flat selector-keyed object as `data.get()` and is called regardless of where the change originates
![The image shows the Shopware administration's CMS layout editor. The current layout only has one block with a Dailymotion CMS element. The block shows the paused preview of the configured video.](../../../../assets/add-cms-element-via-admin-sdk-element.png "Dailymotion CMS element")
### The preview file
`swag-dailymotion-preview.vue` is the thumbnail shown in the block picker when a user browses the *Video* category.
In most cases it contains minimal logic — a static image, a skeleton, or a logo is sufficient:
```html
<template>
  <h2>Preview!</h2>
</template>
![The image shows the "Replace element" modal to replace the current block with another element. Depicted is the Dailymotion element which has the text "Preview!" as the element preview as configured in this example.](../../../../assets/add-cms-element-via-admin-sdk-preview.png "Dailymotion element preview")
## Storefront implementation
After completing the admin implementation, you also need a Storefront representation of your blocks. This is similar to typical plugin development, except for the path. All Storefront templates must follow this pattern:
`<app-name>/Resources/views/storefront/element/<elementname>.html.twig`
For more details, see the guide on [CMS element development for plugins](../../plugins/content/cms/add-cms-element#storefront-implementation).
Below is an example of how your storefront template
(`SwagBasicAppCmsElementExample/Resources/views/storefront/element/cms-element-swag-dailymotion.html.twig`) could look:
```twig
{% block element_swag_dailymotion %}
<div class="cms-element-swag-dailymotion" style="height: 100%; width: 100%">
    {% block element_dailymotion_image_inner %}
    <div class="cms-el-swag-dailymotion">
        <div style="position:relative; padding-bottom:56.25%; height:0; overflow:hidden;">
            <iframe style="width:100%; height:100%; position:absolute; left:0px; top:0px; overflow:hidden"
                    src="https://www.dailymotion.com/embed/video/{{ element.config.dailyUrl.value }}"
                    frameborder="0"
                    type="text/html"
                    width="100%"
                    height="100%">
            </iframe>
        </div>
    </div>
    {% endblock %}
</div>
{% endblock %}
